Correcting false power values reported by Data Center Expert 7.2.6
DCO Troubleshooting
  • EcoStruxure IT Help Center
  • IT Advisor
  • DCO
  • DCO Troubleshooting
  • Correcting false power values reported by Data Center Expert 7.2.6
  • Mark as Read
  • Resolving error collecting data
  • Reset password for the DCO client
  • How to install a genome only update
  • Downloading log files for troubleshooting
  • Correcting false power values reported by Data Cen...
EcoStruxure IT Support
Request Support
Back to DCO Troubleshooting
  • Mark as Read
Picard EcoStruxureIT
‎2020-02-28 06:38 AM
Some rack-mount PDUs reporting power bank information to Data Center Expert 7.2.6 report wrong power and current data to Data Center Operation.
Known affected devices: AP8970, AP8888, AP8886, AP8881, AP8870, AP8862, AP8860, AP8853, AP8841, AP8832J, AP8831, AP8653, AP8632, AP8481, AP8441, AP7960, AP7853 ...
You will be able to see if your rack-mount PDUs are reporting incorrectly to DCO if you see a significant difference in a rack-mount PDU's total peak and average values per phase in DCO compared with DCE. This can be done by running a power sensor report of the device(s) in DCE for a time period of 30 days. This report will also show the average and peak values in the bottom table. These numbers can then be compared with the power data seen in the device properties in DCO.
This patch fixing the issue applies to DCE 7.2.6+:
DCE version
DCO version
Fix includes
7.2.6 and later Prior to 7.5 Power (kW)
7.2.6 and later 7.5 and later
Power (kW), Current (amps)
How do I know if my rack-mount PDUs might be reporting wrong power data to DCO?
  1. Click View Device Sensors on your device (rack-mount PDU) in DCE (e.g. AP8841).
  2. Look for Power - Bank 1 and Power - Bank 2.
  3. If the device has more than one power bank, it could be reporting wrong power data to DCO.
How do I apply the patch in DCE?
  1. Make sure to have a recent backup in place of your running systems before applying the patch.
  2. On the DCE server, open this URL: http://<DCE server ip>/nbc/status/SensorContexts.
    You must be logged in as an admin user.
    1. If you already have a previous version of this patch installed (prior to March 2016), remove the existing file: pduSensorUpdates.xml before proceeding.
  3. Download this file and upload it to the DCE server.
    The file has now been uploaded to the server and the patch is in place.
    Warning
    Uploading a malformed or corrupted file can totally mess up the system.
The power values are now correctly transferred.
You can erase the false power data history and see the corrected values immediately* by deleting the external system (DCE) in DCO and adding it again. You will need to associate devices again in DCO.
*Once the data has been gathered from DCE. It might take up to 1 day depending of number of devices.
An alternative is waiting. Depending on the configuration in Data Center Operation (30 days by default), all the values will be corrected after the configured time period (30 days by default). In general, power data is stored for a year for report purposes so for reports, the data will take longer for the data to be fully corrected.
    Warning
