Resolving error collecting data
DCO Troubleshooting
  • EcoStruxure IT Help Center
  • IT Advisor
  • DCO
  • DCO Troubleshooting
  • Resolving error collecting data
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to DCO Troubleshooting
  • Mark as Read
Picard EcoStruxureIT
‎2020-05-13 05:38 AM
The Error collecting data message typically occurs if Data Center Operation is unable to receive data from Data Center Expert. There could be several reasons for the server response to be cut off. Start by ruling out the listed scenarios.
Why do I see this error?
How do I resolve this?
  • Network infrastructure between the two servers.
  • Changes to DCE user credentials or update of the SSL certificate.
  • Ping the servers to ensure they are running and check your network path to rule out general network related issues.
  • Test the DCO/DCE server connection (in DCO select System Setup > External Systems Configuration. Perform the test for both port 80 and 443 (use encryption).
    Don't change the DCE server ID (IP/hostname) as part of the test because this will result in all device associations being lost.
  • The DCE server may be under too much stress and unable to run the necessary background jobs.
  • The DCE server may be unable to handle requests from the IT Advisor server.
  • Reboot the DCE server to re-initiate the jobs.
  • If the server is stressed because it is monitoring too many devices, consider additional purchases.
If the connection was lost or interrupted, DCO will collect any data it missed when the connection has been restored.
