Server SSL Certificates
DCE server administration settings
Send InviteCancel
Manage the SSL certificates on the server used for secure communication with an SMTP server, Active Directory or OpenLDAP server, NetBotz Appliance, or for working with chain SSL certificates used with the DCE web server.
When you select NetBotz Appliance in the device discovery process, and select the security mode Require SSL, validate certificates option, you use this display to add the certificate from the NetBotz Appliance you want to discover to the Data Center Expert server first. Otherwise, device discovery will not complete successfully.
Note: Adding and removing server SSL certificates for secure communication with an SMTP server, Active Directory or OpenLDAP server, or a NetBotz Appliance does not require the Data Center Expert server to reboot.
Click Add to import a certificate from a file, or paste a certificate into the text field.
Click Remove to remove the selected certificate from the Data Center Expert server.
Click View for the details of the selected certificate.
