Syslog settings option
DCE server administration settings
Send InviteCancel
Configure settings in Data Center Expert to forward event log messages to an external Syslog server.
Go to System > Server Administration Settings > Syslog Configuration.
All the data in the event log messages are transmitted over Syslog, including usernames, email addresses, and information about share locations. Note: Syslog functionality may differ depending on the Syslog server being used.
Element
Description
Enable Syslog integration
Check to forward event log messages to an external Syslog server.
Syslog server
Specify the hostname or IP address of the Syslog server.
Port
Specify the port for the Syslog server, 514 by default.
Message format
Specify the message format for the Syslog server, RFC_3164 by default.
Facility
Specify the facility for the Syslog server, AUDIT by default.
Protocol
Specify the protocol used to communicate with the syslog server, TCP or UDP.
Timeout
Available when TCP is selected.
How long the server will wait to connect to the Syslog server, 5 seconds by default.
Maximum retries
The number of times the server will attempt to connect to the Syslog server, 2 by default.
Line terminator
The sequence of characters that indicates the end of a line of text, \r\n by default.
Apply and Test
Click to to apply settings to your DCE server. Check the destination Syslog server to verify your configuration.
