Status messages: "Schedule Update Checks" display
DCE device firmware and server updates
  • EcoStruxure IT Help Center
  • DCE device firmware and server updates
  • Status messages: "Schedule Update Checks" display
  • Mark as Read
  • Performing a server update
  • Importing the APC firmware update catalog
  • Performing a firmware update
  • Firmware Update Status view
  • Status messages: Firmware Update Status view (NetB...
  • Status messages: Firmware Update Status view (APC ...
  • Schedule firmware update checks
EcoStruxure IT Support
Request Support
Back to DCE device firmware and server updates
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:12 AM
Four different status messages can appear when you use the display for Schedule Update Checks in the Settings menu.
Message Description
The next update check is set to occur on <Date> at <Time>. Reports the date and time for the next scheduled update check.
Recommended Action: None
The scheduled update checking service is disabled. The Check for Updates option is not selected.
Recommended Action: Select to enable scheduling.
Unable to schedule the specified update check. An unexpected server error occurred.
Recommended Action: Try again. If the problem persists, contact APC Support (http://www.apc.com/support).
Cannot schedule the updates check. Based on the server's time settings, the selected time is in the past. You attempted to use an invalid date or time to schedule a check for updates.
Recommended Action: Use a time setting that is in the future.
