Status messages: Firmware Update Status view (NetBotz Appliances)
DCE device firmware and server updates
  • EcoStruxure IT Help Center
  • DCE device firmware and server updates
  • Status messages: Firmware Update Status view (NetBotz Appliances)
  • Mark as Read
  • Performing a server update
  • Importing the APC firmware update catalog
  • Performing a firmware update
  • Firmware Update Status view
  • Status messages: Firmware Update Status view (NetB...
  • Status messages: Firmware Update Status view (APC ...
  • Status messages: "Schedule Update Checks" display
  • Schedule firmware update checks
EcoStruxure IT Support
Request Support
Back to DCE device firmware and server updates
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:12 AM
Several different status messages can be reported in this view for NetBotz Appliance updates initiated by selecting Apply Firmware Updates in the Updates menu.
Message Description
Failed to update device firmware. An unknown error occurred.
Recommended Action: Make sure the NetBotz Appliance is turned on and online, its HTTP or HTTPS web service is enabled, and the "NetBotz Appliance Credentials" display accessed from Server Administration in the Settings menu includes the correct IP Address, Port, Username, and Password settings.
Correct any network connection problem.
If the problem persists, contact APC Support (http://www.apc.com/support).
Failed to update the device: unable to connect. A network or HTTP/HTTPS communication problem exists.
Recommended Action: Make sure the NetBotz Appliance is turned on and online, its HTTP or HTTPS web service is enabled, and the "NetBotz Appliance Credentials" display accessed from Server Administration in the Settings menu includes its correct IP address and port settings.
Note
Once the problem is corrected, select Apply Firmware Updates in the Updates menu to update the device.
Failed to update device: unable to log on. The server does not have the FTP access settings needed to log on to the device, or communication was lost after the connection was successful.
Recommended Action: Make sure the "NetBotz Appliance Credentials" display accessed from Server Administration in the Settings menu includes the correct Username and Password for the NetBotz Appliance.
Make sure the device has not been turned off or disconnected from the network.
Note
Transferring update... ({0}% The update is being transferred, with how much of the transfer has occurred reported as a percentage.
Update completed successfully.
The update was successful.
Recommended Action: None
Update pending... The update is pending, but not started.
Update started...
The update has started.
Waiting for NetBotz Appliance to load update... The update still needs to be loaded at the NetBotz Appliance.
