Firmware Update Status view
DCE device firmware and server updates
Send InviteCancel
An update status view is available using the Firmware Updates option accessed from Device in the Window menu.
Element
Description
List
Provides information about the update at each device selected for a firmware updates process, either an ongoing process, or the last process performed.
Hostname: the device hostname or IP address
Model: device model
Status: status of the update
App Version: application (App) version number of the update
OS Version: operating system (OS) version number of the update
Note
Reported for SNMP device updates only.
Time Completed: when the update finished
Firmware Update Progress
Identifies the number of Updates in progress, Updates canceled, Updates completed, and Successful updates.
Cancel Pending Updates
Click to cancel pending device updates.
Note
The Data Center Expert server can process device updates for up to 20 devices at a time. This button appears in the Firmware Update Status view only, and only when more than 20 devices were selected to be updated.
For example, if 77 devices are selected, Cancel Pending Updates appears when the first set of 20 devices begins to be processed. You can click Cancel Pending Updates at this point to cancel the remaining 57 updates.
If you chose not to cancel the pending updates, the button remains in the view while the second and third sets of 20 devices are processed, and disappears when the last set of 17 devices begins to be processed.
