Device File Transfer Settings
DCE device discovery
Send InviteCancel
Functionally identical versions of this display are used by the Device > SNMP Device Communication Settings > Device File Transfer Settings option and:
SNMPv1/SNMPv3 Device Discovery wizard
Apply Firmware Updates wizard
APC SNMP Device Configuration wizard
A change saved in one display is reflected in all.
To use FTP for APC SNMP device access, FTP server access must be enabled at that device.
To use SCP for APC SNMP device access, Secure Shell version 2 (SSHv2) console access must be enabled at that device.
Note: By default, the Data Center Expert server can download firmware via FTP only to devices that use apc (lowercase) for the username and password. The credentials used for device access are identified in the Device File Transfer Settings display.
