Editing a device discovery process
DCE device discovery
  • EcoStruxure IT Help Center
  • DCE device discovery
  • Editing a device discovery process
  • Mark as Read
  • NetBotz 750 appliance discovery process in DCE
  • Device discovery processes
  • Creating a discovery process
  • Saved Discoveries view
  • Device File Transfer Settings
EcoStruxure IT Support
Request Support
Back to DCE device discovery
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:14 AM
You can edit the discovery settings, the device group, and scheduling for any discovery process listed in the Saved Discoveries view. You cannot edit the type of device the process will discover.
The difference in the three types of discovery processes is the type of settings used to define the process.
  1. Select Saved Discoveries view, a Device option in the Window menu, to access the Saved Discoveries View.
  2. Right-click a listed discovery process and select Edit.
  3. In the discovery settings display, edit the settings, as appropriate, and click Next, to change the scheduling or run (or both) the edited process, or Finish, to save the changes in the Saved Discoveries view without running or scheduling the process.
  4. In the "Choose Device Group" display, edit the device group, as appropriate, and click Next.
  5. In the "Discovery Scheduling" display, do one or both of the following actions, and click Finish, to add the process to the Saved Discoveries view.
    • Use the Enable discovery scheduling option to schedule the days and times when the discovery process will be run automatically.
    • Use the Run discovery now option to run the discovery process when you click Finish.
