"Too many panels opened" when opening ninth panel in Pinpoint
  • "Too many panels opened" when opening ninth panel in Pinpoint
  • RandyDavis
    RandyDavis
  • Sampath_Konda
    Sampath_Konda
  • Alan_Wood
    Alan_Wood
  • CraigEl
    CraigEl
‎2018-09-11 01:24 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 05:16 PM
A dialog box pops up in Pinpoint that says "Too many panels opened. Please close some to continue." when attempting to open more than 8 panels.
Andover Continuum
  • Continuum Cyberstation
  • Pinpoint
  • Windows XP
  • Windows 7
  • Windows Server 2003
  • Windows Server 2008
A limitation has been built into 1.94 to restrict the number of panels open.  Having too many panels open can cause instability with the Pinpoint application. This is a restriction in the code.
There can only be 8 panels open in Pinpoint. Add points to another panel. Monitor system performance. There should be less 100 links per panel.
See also, Pinpoint crashes when jumping between Graphic panels.
Tags (2)
  • 12939
  • SampathKonda19
