Xenta Servers support in StruxureWare Building Operations
  • Xenta Servers support in StruxureWare Building Operations
  • Cody_Failinger
    Cody_Failinger
  • Jonas_Brissman
    Jonas_Brissman
  • CraigEl
    CraigEl
  • Benji
    Benji
  • sesa150555
    sesa150555
‎2018-09-10 12:06 PM
Last Updated: Janeway Jonas_Brissman Janeway ‎2022-08-12 01:47 AM
Are Xenta Servers supported in StruxureWare Building Operations?
  • Xenta 701, 711, 721, 731, 511, 527, 555
Want to use Xenta Server as a controller in StruxureWare Building Operations.
No there are no special support for Xenta servers. But you can add them as normal LonWorks devices. You can only read/write SNVTs from the Xenta server.
Normal Lon rules applies here, you can have a maximum of 64 nodes to a segment (we recommend to keep it under that). TAC Xenta Server I/O modules will not be seen in StruxureWare Building Operation, but they will count towards the 64 nodes on the segment. See Maximum number using StruxureWare Building Operation (Scalability and Capacity) for more information on Lonworks units in StruxureWare Building Operation.
Tags (2)
  • 8361
  • JonasBrissman22
