Xenta 121 floating control resynchronization
  • Xenta 121 floating control resynchronization
  • Cody_Failinger
    Cody_Failinger
  • CraigEl
    CraigEl
  • Anonymous user
‎2018-09-07 06:49 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 04:55 PM
How and when does a Xenta 121 resynchronize floating control outputs?
TAC Vista, EcoStruxure Building Operation
Xenta 121 - All versions
Documented reasons for floating control resynchronization on a Xenta 121 controller.
There are 3 events that cause a Xenta 121 to resynchronize its floating control output logic. These reasons are:
  1. After a restart of the controller from a power cycle or reset command. The resynchronization is randomly initiated within the first 42 minutes after this restart. Testing shows an average of 20 minutes.
  2. After the controller is powered up and has done it's initial resynchronization, it will resynchronize every 18 hours there after.
  3. Commanding the snvt_switch input nviDOResync value member to  >0, and the state member to =1
Please see Programming SNVT_Switch in Menta for instructions on how to program snvt_switch in Menta.
Labels (2)
  • 4709
