Xenta 102-AX Terminal load will not change from 0%
  • Xenta 102-AX Terminal load will not change from 0%
  • RobertAndriolo
    RobertAndriolo
  • David_Purser
    David_Purser
  • PeterLarsen
    PeterLarsen
‎2018-09-11 03:56 AM
Last Updated: Picard RobertAndriolo Picard ‎2020-05-18 06:13 PM
The Xenta 102-AX VAV controller does not indicate any terminal load even though the demand is present at the VAV.
IE the VAV setpoint is 23°C degrees and the room temperature is 26°C degrees.
EcoStruxure Building Operation, TAC Vista
The 102ax has been left in calibration mode. When the 102ax is in this mode the terminal load remains at 0%
To check this from Vista locate the two points "UCPTvavselection.CPH" and "UCPTvavselection.CPl". These object are located in the VAV_controller object of the 102-AX controller.
If one indicates "CALIBR ACTIVE" then the 102-AX  is in airflow calibration mode.
This screen capture shows a Normal state of a 102-AX.
To allow the terminal load to respond complete the Airflow calibration.
If this has been left this way and no calibration is required a power cycle of the 102-AX will remove the 102-AX from airflow calibration mode.
If above was not resolution, then perform the following:
  1. Record all settings (screenshot or photos of TGML Configuration pages)
  2. Commission controller with Default values.
  3. Re-enter all values that were changed from default.
  4. Override temperature above effective setpoint + cooling band, and see if terminal load goes +100. Override temperature below effective setpoint  - heating band, and see if terminal load goes -100.
Labels (2)
Tags (2)
  • 13367
  • zero
