Windows installer fails to install an application
  • Windows installer fails to install an application
  • Katha
    Katha
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-11 09:11 AM
Last Updated: Administrator CraigEl Administrator ‎2025-10-12 04:52 PM
The Windows Installer fails to complete the installation of an application. This may occur across various Windows operating systems.
Andover Continuum, EcoStruxure Building Operation, Satchwell BAS & Sigma, Satchwell MicroNet, TAC IA Series, TAC INET, TAC Vista
  • Microsoft Windows Server 2003
  • Microsoft Windows Server 2003 R2
  • Microsoft Windows XP
  • Windows 7
  • Windows Server 2008
  • Windows Server 2008 R2
  • Windows Vista
  • Windows 8
  • Windows 8.1
  • Windows 10
  • Windows Server 2012 editions
  • Windows Server 2012 R2
Installation failures may result from:
  • Corrupted system files
  • Incomplete previous installations
  • Conflicts with existing software
  • Unsupported OS versions or outdated service packs
For Windows 10:
Use the official Microsoft Program Install and Uninstall Troubleshooter:
🔗 Launch Troubleshooter
Note: This tool is not supported on earlier versions of Windows or Windows Server.
For Other Windows Versions:
Manual troubleshooting steps may be required:
  1. Run System File Checker (SFC):
    Open Command Prompt as Administrator and run:
    sfc /scannow
  2. Check Windows Installer Service:
    Ensure the service is running:
    • Press Win + R, type services.msc, and locate Windows Installer
    • Right-click → Start (if not running)
  3. Clear Temporary Files:
    Use Disk Cleanup or manually delete files from %temp%
  4. Review Event Viewer Logs:
    Look for installation-related errors under Windows Logs → Application
  5. Verify OS Compatibility:
    Confirm your OS version is supported by the application and has the latest updates.
Additional Notes
  • Always verify the official Microsoft support status for your OS version to ensure compatibility and security.
Labels (9)
  • CCTV
  • EcoStruxure Building Expert
  • Satchwell BAS & Sigma
  • Satchwell MicroNet
  • TAC IA Series
  • TAC INET
Tags (2)
  • 18086
  • KatharineVasquez25
