Will the first generation Modbus RTU xdriver work on the CX9200?
  • Will the first generation Modbus RTU xdriver work on the CX9200?
  • Alan_Wood
    Alan_Wood
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 12:17 PM
Last Updated: Administrator CraigEl Administrator ‎2025-08-29 03:00 AM
Users may encounter difficulties when attempting to use the first-generation Modbus RTU XDriver with the CX9200 controller.
Andover Continuum
  • CX9200
  • X-Driver
  • Modbus RTU
The issue typically arises due to uncertainty around compatibility between legacy drivers and newer controller hardware.
The CX9200 is fully compatible with the first-generation Modbus RTU XDriver.
There are no known limitations or issues when deploying this driver on the CX9200 platform.
Additional Notes
  • Ensure that the driver is correctly installed and configured according to the standard Modbus RTU setup guidelines.
  • If communication issues persist, verify baud rate, parity, and device addressing settings.
  • For advanced troubleshooting, refer to the Modbus RTU Integration Guide or contact Schneider Electric support.
Tags (2)
  • 8045
  • AlanWood25
