Will EcoStruxure Building Operation provide any indication of a failure sending a SNMP trap?
  • Will EcoStruxure Building Operation provide any indication of a failure sending a SNMP trap?
  • Mahmoud_Sayed
    Mahmoud_Sayed
  • RobertAndriolo
    RobertAndriolo
  • AbeMeran
    AbeMeran
‎2018-09-11 08:21 AM
Last Updated: Administrator CraigEl Administrator ‎2024-03-11 11:49 PM
  • Building Operation Automation Server
Need to receive an alarm and event if an EBO server couldn't send an SNMP trap.
If there is a failure sending an SNMP trap, EBO will generate a system alarm/event indicating that the trap could not be sent. Note though, that if the trap is sent successfully there is no indication or log entry to indicate so.
System Alarm ID Description
SNMP send trap failure
Failed to send SNMP message.
Tags (2)
  • 17905
  • MahmoudSayed24
