VMware ESXi/ESX Promiscuous mode setup for PCT
  • VMware ESXi/ESX Promiscuous mode setup for PCT
  • Gary
    Gary
  • JohnBoehmer
    JohnBoehmer
  • PeterEdvik
    PeterEdvik
  • Taylor_Leach
    Taylor_Leach
  • StephenYang
    StephenYang
  • CraigEl
    CraigEl
‎2018-09-10 10:08 AM
Last Updated: Gary Schneider Alumni (Retired) ‎2022-08-22 02:03 AM
Receive “Timeout while waiting for server to get ready” error when starting PCT
EcoStruxure Building Operation, Project Configuration Tool
Project Configuration Tool, PCT
PCT can't reach DHCP-server from the virtual machine.
To configure a port group or virtual switch to allow promiscuous mode:
1.Log into the ESXi/ESX host or vCenter Server using the vSphere Client.
2.Select the ESXi/ESX host in the inventory.
3.Click the Configuration tab.
4.In the Hardware section, click Networking.
5.Click Properties of the virtual switch for which you want to enable promiscuous mode.
6.Select the virtual switch or port group you wish to modify and click Edit.
7.Click the Security tab.
8.From the Promiscuous Mode drop  down menu, click Accept.
Note: The setting on the port group overrides the virtual switch setting. For more information, see How promiscuous mode works at the virtual switch and portgroup levels (1002934).
[video]
Labels (2)
  • Project Configuration Tool
Tags (3)
  • 19728
  • GaryMontague22
  • StephenYang20
100% helpful (1/1)
