Using DSL with Continuum controllers
  • Using DSL with Continuum controllers
  • Cody_Failinger
    Cody_Failinger
  • PaulFr
    PaulFr
  • Alan_Wood
    Alan_Wood
  • CraigEl
    CraigEl
‎2018-09-07 05:46 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 05:25 AM
If remote buildings have an internet connection using DSL, will this configuration work with Continuum controllers? Are there any known issues? Is the connection fast enough?
Andover Continuum
  • Netcontroller 9680
  • Netcontroller 99xx
  • BCX
  • ADSL (Asynchronous Digital Subscriber Line)
Buildings in remote areas may use DSL(Digital Subscriber Line) to access Netcontrollers instead of a corporate LAN.
Netcontrollers can be used with a DSL connection. Two things to keep in mind when implementing this configuration are:
  1. Do not employ NAT(Network Address Translation) of any kind. Continuum requires a static IP. This can be requested from the ISP(Internet Service Provider) of the DSL line.
  2. All network ports required for Continuum operation will need to be opened. See Router required open port numbers to run a Continuum system for this information.
DSL speeds are typically fast enough to not cause connection issues.
Note: Where DSL lines have equal up and download speeds, ADSL (Asynchronous Digital Subscriber Line) have upload speeds that may be 100 x slower than the download speed, typically 128K maximum and are unlikely to provide a reliable network connection.
  • 4554
