Unable to use Heat Pump application on SE8000
  • Unable to use Heat Pump application on SE8000
  • RandyDavis
    RandyDavis
  • Ramaaly
    Ramaaly
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-06 09:27 AM
Last Updated: Picard RobertAndriolo Picard ‎2022-04-04 04:57 PM
There are only fan coil control applications available and unable to find the Heat Pump Application.
  • Building Operation Workstation
  • Building Operation Automation Server
  • SSL SE8000
The end-user might be using an incompatible controller for their application.
Heat pump applications for the SE8x00 product are scheduled for availability in the 4th quarter of 2014.
  • TAC IA Series
Tags (2)
  • 16659
  • RamaAly22
