Unable to control Door outputs on an SP-C when configured as an onboard Reader Expander.
  • Unable to control Door outputs on an SP-C when configured as an onboard Reader Expander.
  • RandyDavis
    RandyDavis
  • HenrikTarpgaard
    HenrikTarpgaard
  • CraigEl
    CraigEl
  • AdamSteele
    AdamSteele
‎2018-09-10 09:30 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-11 09:54 PM
Unable to control Door output on SP-C when configured as onboard Reader Expander. Manual control of the Door outputs work but the Reader Expander will not control the Door outputs when a valid card is read.
EcoStruxure Security Expert
  • Security Expert
  • SP-C
The Controller was not registered as a Reader Expander. This is not done automatically for you when configuring the Controller through the wizard and needs to be done manually to be able to use the onboard readers.
1. Go to Sites > Controllers and on the Configuration tab select the address to Register as Reader Expander and the configuration of the Onboard Reader Lock Outputs.
2. Update modules and download.
Note: In later Security Expert versions, it will say "Controller Relay 3/4 outputs" under "Onboard Reader Lock Outputs".
  • EcoStruxure Security Expert
Tags (2)
  • 19651
  • HenrikTarpgaard21
0% helpful (0/1)
