Trouble retrieving the Controller Error Log from a first generation NetController.
  • Trouble retrieving the Controller Error Log from a first generation NetController.
  • Alan_Wood
    Alan_Wood
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 01:44 PM
Last Updated: Administrator CraigEl Administrator ‎2025-08-29 03:24 AM
When trying to dump the Gerry Log from several controllers on the network, the header and errors appear to be identical.
Andover Continuum
  • CX99xx
  • NetController
  • Controller error log
The NetController requires a direct physical connection via RS232 to access diagnostic logs. Network-based retrieval is not supported for first-generation models.
To successfully retrieve the Gerry Log from a first-generation NetController:
  1. Connect directly to the controller using an RS232 serial cable.
  2. Use the Continuum CyberStation or compatible terminal software to initiate the log dump.
  3. Ensure the correct COM port is selected and communication parameters (baud rate, parity, etc.) match the controller’s settings.
  4. If multiple controllers show identical logs, verify each connection individually to rule out cabling or port configuration issues.
Tags (2)
  • 5335
  • AlanWood25
