Triac Output requirements
  • Triac Output requirements
  • RandyDavis
    RandyDavis
  • JonGreen
    JonGreen
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 09:52 AM
Last Updated: Guinan RandyDavis Guinan ‎2020-02-05 08:44 AM
Unable to control the field device with a Triac output.
EcoStruxure Building Operation, Andover Continuum
  • Continuum b3 Controllers
  • Continuum i2 Controllers
  • Building Operation Multi-purpose Controllers with Triacs
  • Triac outputs cannot switch DC loads.
  • Triac outputs require a minimum 30 mA load in order to switch.
If the inductive load draws less than 30mA a resistor needs to be wired in parallel with the switched load.
Labels (2)
Tags (2)
  • 14990
  • JonGreen20
100% helpful (1/1)
