Transitioning Belimo Bacnet b3865 VAV controllers to an Automation Server
  • Transitioning Belimo Bacnet b3865 VAV controllers to an Automation Server
  • Cody_Failinger
    Cody_Failinger
  • CraigEl
    CraigEl
  • AdamSteele
    AdamSteele
  • sesa177673
    sesa177673
‎2018-09-11 12:57 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 07:08 PM
Transitioning from Continuum to Struxureware Building Operation and replacing bCX's with Automation Servers.
Andover Continuum, EcoStruxure Building Operation
  • b3865
  • Struxureware Building Operation
Unsure if the older belimo style VAV controllers are compatible with StruxureWare Building Operation.
All of the b3xxx controllers (including both the -V and non -V) will work with the Automation Server under it's MSTP network.
Also check out the b3 VAV Quick Start Video on the Community.
Labels (2)
  • 18351
