Temperature Inputs on controller having sporadic readings of +327
  • Temperature Inputs on controller having sporadic readings of +327
‎2018-09-10 08:35 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:19 AM
Fluctuating temperature readings where they jump up to +327 randomly.
Andover Continuum
  • Continuum controllers
  • i2866-V
Readings like that are usually caused by wiring or power issues. There was also a Firmware fault that caused this in an old version of the i2866-V Firmware.
Confirm the following wiring considerations:
  1. That your input and output cables shield is wired to Earth ground at one end of the run only (preferably the controller chassis).
  2. That your controllers power supply is earthed on the secondary side of the 24vac transformer to ensure a proper controller ground to Earth.
  3. Confirm that the power supply is not being shared with any field devices, especially field devices feeding inputs back into the controller.
One way to troubleshoot if it is a cabling or controller problem is to replace the sensor cable with a 10K ohm resistor. See Temperature inputs not reading the correct value for details.
Also, in i2866-V controllers with firmware versions less than v3.501049, temperature inputs could randomly go to +327 when Analog Outputs were changing value frequently. Uprev your controller. See TPA-BOST-09-0007.00 for details.
Tags (2)
  • 7214
  • ACX810
100% helpful (2/2)
