TAC Xenta I/O modules counted as a LonWorks device
  • TAC Xenta I/O modules counted as a LonWorks device
  • RandyDavis
    RandyDavis
  • Jonas_Brissman
    Jonas_Brissman
  • PeterLarsen
    PeterLarsen
Janeway Jonas_Brissman Janeway
‎2020-04-15 08:42 AM
Last Updated: Administrator CraigEl Administrator ‎2023-02-27 06:19 PM
When looking in the EcoStruxure Building Operation Architectural Guidelines for the maximum number of Xenta and LonWorks devices per server, is a TAC Xenta I/O module placed under a TAC Xenta 300/400 counted as a LonWorks device?
  • Building Operation Automation Server
The SmartX Server or Enterprise Server doesn't know that the TAC Xenta I/O module exists if it is placed under a TAC Xenta 300/400. The SmartX Server or Enterprise Server only communicates with the TAC Xenta 300/400 and not the TAC Xenta I/O modules under it.
The TAC Xenta I/O module does not count as a LonWorks device in the EcoStruxure Building Operation Architectural Guidelines if placed under a TAC Xenta 300/400.
This also means a TAC Xenta I/O placed under a TAC Xenta 300/400 does not count as a  Hosted Node or Connected Product.
Tags (5)
  • 300
  • 400
  • JonasBrissman20
  • maximum
  • PeterLarsen23
