Supported LoyTec L-IP Operating Modes in StruxureWare for Building Operation
  • Supported LoyTec L-IP Operating Modes in StruxureWare for Building Operation
  • RandyDavis
    RandyDavis
  • David_Purser
    David_Purser
  • Cody_Failinger
    Cody_Failinger
  • SESA116857
    SESA116857
‎2018-09-11 01:25 AM
Last Updated: Guinan RandyDavis Guinan ‎2022-09-27 07:33 AM
What mode must a LoyTec L-IP be configured to work with EcoStruxure Building Operation?
  • Loytec L-IP
The operating mode limits the capabilities of the LoyTec L-IP when used with an Enterprise Server
Smart Switch Mode
Ensure that the LoyTec L-IP is in Smart Switch mode.
This is achieved by using the DIP switch settings for switches 1 and 2 in the ON position.
Reset Forwarding Tables
Press the status button for at least 20 seconds. This will clear the forwarding group, the subnet/node forwarding, and the router domain table when used in smart switch mode.
Important: If the L-IP is operated in smart switch mode and is moved from one location to another or if major changes to the configuration of the network are made, it is recommended to reset
the L-IP forwarding tables
Important: Wait at least 30 seconds after power-up of the L-IP before pressing the Status Button to ensure that the L-IP has booted properly!
For additional detail please reference the LoyTec L-IP user manual.
Tags (5)
  • 12986
  • DavidPurser22
  • integration
  • lip
  • lon
