Setting up Visual Verification to track who has gained access to a door using Access Expert
  • Setting up Visual Verification to track who has gained access to a door using Access Expert
  • JonGreen
    JonGreen
  • Roger_Bently
    Roger_Bently
  • Cody_Failinger
    Cody_Failinger
Lieutenant Roger_Bently Lieutenant
‎2018-12-05 08:58 AM
Last Updated: Administrator Cody_Failinger Administrator ‎2018-12-07 01:53 PM
Access Expert
Access Expert v3
Verification of access is a common feature request in access control integrations. The following steps show how to enable and access this feature within the Access Expert v3 product.
  1. Open and connect to the instance with the required credentialsInstance Loggon.jpg
  2. Select the Access Control Tab and click on the Visual Verification buttonAccess Tab.jpg
  3. Click on the Assign Reader button to Add the respective readers and click OKAdd Readers.jpg
  4. The Visual Verification Window opens up with the readers that were selected from the previous step on the right side of the screen. Select the necessary readers that will be used for the verification.
  5. Once someone scans a card on any of the selected readers, their saved image will then be displayed
  6. *Note* If this Window is closed the configuration for Visual Verification will be lost and will need to be recreated
  • EcoStruxure Access Expert
