Sensor pocket thread specification
  • Sensor pocket thread specification
  • Cody_Failinger
    Cody_Failinger
  • CraigEl
    CraigEl
  • SESA150559
    SESA150559
‎2018-09-06 03:28 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-08 06:02 PM
Thread size/standard.
Field Devices
Pocket
Well
Pocket STP 50mm Brass  9121040000
Pocket STP 100mm Brass  9121041000
Pocket STP 150mm Brass  9121042000
Pocket STP 200mm Brass  9121043000
Pocket STP 250mm Brass  9121044000
Pocket STP 300mm Brass  9121045000
Pocket STP 400mm Brass  9121046000
Pocket STP 50mm Stainl.steel 9121050000
Pocket STP 100mm Stainl.steel 9121051000
Pocket STP 150mm Stainl.steel 9121052000
Pocket STP 200mm Stainl.steel 9121053000
Pocket STP 250mm Stainl.steel 9121054000
Pocket STP 300mm Stainl.steel 9121055000
Pocket STP 400mm Stainl.steel 9121056000
This information is necessary if an adaptor or similar is required for installation.
The thread is of cylindrical type, and follows DIN 228 and BSP (British Standard Pipe) which both are identical.
Size of thread is G1/2.
For additional information on Pocket materials, please see Sensor pockets material specification Stainless steel and Sensor pockets material specification nickel plated brass.
  • Field Devices
Tags (3)
  • 7666
  • stainless
  • STP Series Pocket STP
100% helpful (1/1)
