Sensor pockets material specification nickel plated brass
  • Sensor pockets material specification nickel plated brass
  • Cody_Failinger
    Cody_Failinger
  • SESA150559
    SESA150559
‎2018-09-06 12:42 PM
Material specification for nickel plated brass sensor pockets
Field Devices
Sensor pockets
Some customers require a specification on the material used for the sensor pockets in nickel plated brass.
  • Brass nickel plated: Turned part: Ms 58 (Cu Zn 39 Pb3) Pipe + lid: Ms 63 (Cu Zn 37)
    Surface nickel plated.
  • Guidelines for nickel plating:
    Galvanica nickel plated ( ca. 6 – 12 µm)
  • Field Devices
  • 7274
