Security Expert supported biometric readers
  • Security Expert supported biometric readers
‎2018-09-10 12:47 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:58 AM
What fingerprint or faceprint readers does Security Expert support?
EcoStruxure Security Expert
  • Security Expert
  • Fingerprint Reader
  • Faceprint Reader
  • Biometric Reader
Require information on what Biometrics readers are supported with Security Expert.
We officially support Suprema, Princeton Identity and IDEMIA biometric readers (see SX SRVR Security Expert - Compatibility Matrix) however our reader expanders/controllers are able to work with any reader that provides a standard 26-bit Wiegand output.
If there is a biometric reader that does this it should be able to be connected to Security Expert like a standard card reader supplying the controller with Wiegand data that is assigned to a user. The enrolling of biometrics would need to be handled by the third party system, we would essentially be treating it as a normal card reader and card.
  • For a list of Suprema devices that Security Expert supports refer to the Suprema Biometric Integration in Security Expert Application Note.
  • For a list of Princeton Identity devices that Security Expert supports refer to the Princeton Identity Biometric Integration  Application Note.
  • For a list of IDEMIA devices that Security Expert supports refer to the IDEMIA Biometrics Integration Application Note.
  • EcoStruxure Security Expert
Tags (3)
  • 19238
  • AdamSteele24
  • HernanUruena23
100% helpful (1/1)
