Security Expert MSMQ is required (Not showing live point status / shows "Unknown Status" error)
  • Security Expert MSMQ is required (Not showing live point status / shows "Unknown Status" error)
  • RobertAndriolo
    RobertAndriolo
  • DavidChild
    DavidChild
  • David_Kendrick
    David_Kendrick
  • AdamSteele
    AdamSteele
‎2018-09-06 07:37 AM
Last Updated: Sisko DavidChild Sisko ‎2021-07-02 07:17 AM
Security Expert client Status Window is not showing live point status for inputs, outputs, doors. Shows an error message “Status Unknown” instead. The client is still however able to receive access control events such as reader entry/exit.
EcoStruxure Security Expert
Security Expert
MSMQ (Microsoft Message Queueing) is not enabled. This is a requirement for MSMQ to be installed on the Security Expert Server, the Security Expert Client machines do not need this but the machine where the Security Expert Services are installed does need this feature installed to function properly.
Windows 10
In Windows Features settings (Turn Windows features on or off) turn on the “Microsoft Message Queue (MSMQ) Server” and the “Microsoft Message Queue (MSMQ) Server Core” features.
Windows Server 2016 or above
Start Server Manager.
Select Manage / Add Roles and Features.
Click Next.
Select Role-based or Feature-based installation
Click Next.
Select the server where to install the feature.
Go to Features, and navigate to Message Queuing / Message Queuing Services and select Message Queuing Server.
Click Install to start the installation.
The setup may require a system restart. Click OK to finish.
  • EcoStruxure Security Expert
Tags (4)
  • 19260
  • DavidKendrick20
  • DavidKendrick21
  • RobertAndriolo20
100% helpful (1/1)
