SSC Fails to communicate
  • SSC Fails to communicate
  • Cody_Failinger
    Cody_Failinger
  • Roger_Bently
    Roger_Bently
‎2018-09-06 07:37 AM
After setting up an SSC controller, it does not come online even after multiple Resets and putting it into DFU Mode.
Access Expert
  • Access Expert
  • Windows Server 2012
The device was previously set up, maybe at the office. Now, when taken out to site, it shows that it already exists on another instance.
  1. Open up the initial instance that it was set up on
  2. Right click and Delete the device
  3. Open up the new instance that it will be current on
  4. If already created, then communication should start automatically
  5. Once online, program accordingly
  • EcoStruxure Access Expert
Tags (4)
  • 19298
  • offline
  • readers
  • working
