SE8000 OA (Outside Air) Damper is not Functioning as expected
  • SE8000 OA (Outside Air) Damper is not Functioning as expected
  • RandyDavis
    RandyDavis
  • Ramaaly
    Ramaaly
  • PatrickDumas
    PatrickDumas
  • JohnBoehmer
    JohnBoehmer
Lt. Commander Ramaaly Lt. Commander
‎2021-11-01 08:49 AM
Last Updated: JohnBoehmer Schneider Alumni (Retired) ‎2021-12-21 08:24 AM
Unable to configure the OA (outside Air) Damper control of SE8000 to work as desired for free cooling and CO2 (Ventilation)
EcoStruxure Building Operation, EcoStruxure Building Expert
  • Building Operation Workstation
  • Building Operation Automation Server
  • SSL SE8000
The damper control on the SE8000 is restricted to the minimum position under the following conditions:
  • Econo.config parameter is set to off
  • The CO2 value is 0 or lower than Min CO2 Parameter (adjustable)
  • The OA (Outside Air) is warmer than Changeover SP (adjustable)
  • The SA (Supply Air) temperature is colder than Supply air SP (adjustable)
  • The parameter Mech. Cooling is set to OFF
[video]
  • EcoStruxure Building Expert
Tags (3)
  • co2
  • RamaAly21
  • se8000
