Restoring backups when Vista Server is a service
  • Restoring backups when Vista Server is a service
  • Cody_Failinger
    Cody_Failinger
  • CraigEl
    CraigEl
  • SESA116857
    SESA116857
‎2018-09-07 10:04 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 01:33 AM
When Vista Server is running as a service how do you restore backup files?
TAC Vista
  • Vista 4.x.x
  • Vista 5.x.x
The Vista Server program will not allow you to restore a backup when running as a service. Depending on the nature of the backup it might have to be deregistered as a service to do the restore.
Vista backup is a zip file of the database directory
  1. Open Services from the Windows Control Panel.
  2. Stop the Vista Server service (TACOS.exe)
  3. Unzip the database backup into an empty directory of your choice.
  4. Start Vista Server Setup and browse to the directory the database was restored to in the Database folder path of the Vista Database tab.
  5. Click Ok.
  6. Start the Vista Server service (TACOS.exe)
Vista backup is a full Vista backup (FVB) file
  1. Unregister Vista Server as a service, see Registering/Unregistering TAC Vista Server as a Windows service.
  2. Start Vista Server as a program.
  3. Login to the Vista Server program.
  4. Use the File\Restore Database option.
  5. Browse to the FVB file.
  6. Browse to a new folder.
  7. Click Ok.
  8. Close Vista Server.
  9. Start Vista Server Setup and browse to the directory the database was restored to in the Database folder path of the Vista Database tab.
  10. Click OK.
  11. Start Vista Server as a program.
  12. Ensure the database was upgraded.
  13. Stop Vista Server.
  14. Register Vista Server as a service, see Registering/Unregistering TAC Vista Server as a Windows service.
  • 5008
