Report object setup to output to directory does not save to multiple files
  • Report object setup to output to directory does not save to multiple files
  • AdamSteele
    AdamSteele
  • RobertAndriolo
    RobertAndriolo
  • CraigEl
    CraigEl
‎2018-09-10 01:24 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 10:27 PM
Report setup to automatically save to unique files in an output directory is not working. When ReportCmdLine.exe is used to save the report output (see Automatically Running Continuum Standard Reports) only a single file is created and overwritten each time.
Andover Continuum
  • Continuum Cyberstation
  • Continuum Report object
The name of the Report object being run has a period (.) in its name.
Rename the Report object removing the period from its name. The Report output will now save a new file with date and time in the filename each time it is run.
  • 18814
