Replacement of Drayton Theta ll ES4 Optimiser Controller by Satchwell SVT Optimiser Controller due to obsolescence
  • Replacement of Drayton Theta ll ES4 Optimiser Controller by Satchwell SVT Optimiser Controller due to obsolescence
  • Cody_Failinger
    Cody_Failinger
  • CraigEl
    CraigEl
  • sesa125819
    sesa125819
‎2018-09-06 01:40 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 01:41 AM
Drayton Theta ll ES4 Optimiser Controller requires replacement.
Field Devices, Satchwell Sigma
  • Stand alone discreet Drayton Optimiser Controller
  • Theta ll ES4
Obsolescence of Drayton Theta ll ES4 Optimiser Controller.
Please note that the Satchwell SVT controller is no longer available, and that the only possible replacement is the DC1400. Please refer to What is the replacement for the SVT controller range? for more details.
Replace Drayton Theta ll ES4 Optimiser Controller with Satchwell SVT Optimiser Controller.
N.B.
Two models of the Satchwell SVT Optimiser Controller are available :-
SVT 4201 with Analogue Timeswitch
SVT 4251 with Digital Timeswitch,
Details of the Satchwell SVT Optimiser Controllers may be viewed here.
It should also be noted that the associated Drayton Theta ll ES4 Optimiser Controller Sensors are obsolete.
These Sensors are not compatible with the Satchwell SVT Optimiser Controllers and must therefore be replaced.
Unlike the Drayton Theta ll ES4 Optimiser Controller, which requires the installation of both an Outside Air Temperature Sensor and an Inside Air Temperature Sensor, the Satchwell SVT Optimiser Controllers require the installation of a Inside Air Temperature Sensor only.
A STR 614 Inside Air Temperature Sensor is packed with the Satchwell SVT Optimiser Controller when supplied new :-
Details of the STR 614 Room Temperature Sensor may be viewed here.
Labels (2)
  • Field Devices
  • Satchwell BAS & Sigma
  • 5681
