Remote Alarm Manager, GSM modem does not send text message.
  • Remote Alarm Manager, GSM modem does not send text message.
  • CraigEl
    CraigEl
  • sesa125819
    sesa125819
‎2018-09-06 01:50 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-20 05:20 PM
The GSM modem fails to send a text message when an alarm is generated in the Sigma Remote Alarm Manager.
Satchwell BAS & Sigma
Remote Alarm Manager (RAM)
The issue is typically due to incorrect configuration within the Remote Alarm Manager, particularly in the recipient settings or interface selection.
  1. Verify Configuration Settings:
    • Open the Remote Alarm Manager configuration interface.
    • Navigate to the Recipient Configuration section.
  2. Check Interface Selection:
    • Ensure the correct communication interface is selected for the GSM modem.
    • Confirm that the modem is properly connected and recognized by the system.
  3. Test Modem Functionality:
    • Attempt to send a manual test SMS from the Remote Alarm Manager.
    • If the modem does not respond, check for error messages such as:
      • "Unable to reset GSM modem"
      • "Modem did not accept reset command"
  4. Review Common GSM Modem Compatibility:
    • Refer to the list of commonly used GSM modems compatible with RAM.
    • Ensure your modem model is supported and configured according to Schneider Electric guidelines.
  5. Restart and Retest:
    • Restart the Remote Alarm Manager service.
    • Trigger a test alarm to verify SMS delivery.
Additional Resources
  • Sigma - Remote Alarm Manager - Commonly used GSM modems
Labels (3)
  • Satchwell BAS & Sigma
  • Satchwell MicroNet
Tags (2)
  • 5231
  • CraigEllis25
