Sigma - Remote Alarm Manager - Commonly used GSM modems.
  • Sigma - Remote Alarm Manager - Commonly used GSM modems.
  • Gary
    Gary
  • CraigEl
    CraigEl
  • sesa125819
    sesa125819
‎2018-09-07 08:44 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-19 07:54 PM
GSM modems that can be used with the Remote Alarm Manager.
Satchwell BAS & Sigma,Satchwell MicroNet,TAC Vista
  • Remote Alarm Manager.
  • BAS Sigma Micronet Vista
  • GSM RAM
  • Siemens TC35i
  • Siemens MC52i
  • Multi-Tech MTCBA-G-F4-GB/IE
  • Cinterion MTX-65+G-V53
Not all GSM modems will allow the full functionality of message acceptance in the Remote Alarm Manager.
The following GSM modems are known to provide the full message acceptance of the Remote Alarm Manager.
  1. Siemens TC35i GSM modem terminal. In the Remote Alarm Manager configuration select the C35i driver.
    This modem is now being replaced be the Cinterion (Siemens) MC52i GSM/GPRS Dual band modem terminal, which has not been tested, but appears to be a direct replacement with added functionality.
    TC35i GSM/GPRS modem terminal data sheet
    MC52i GSM/GPRS modem terminal data sheet
  2. Multi-Tech MultiModem MTCBA-G-F4-GB/IE modem terminal. In the Remote Alarm Manager configuration select the Brodersen UCM 91/92.
    This modem is still available, but seems expensive and difficult to source.
    MultiTech MultiModems MTCBA-G-F4 data sheet
  3. Cinterion MTX-65+G-V53 modem terminal.In the Remote Alarm Manager configuration, allow the software to locate the modem and use a generic driver.
    Cinterion MTX-65+G-V53 modem terminal data sheet
Remote Alarm Manger is no longer a support solution, it is recommended transitioning or upgrading to EcoStruxure Building Operation.
Labels (3)
  • Satchwell BAS & Sigma
  • Satchwell MicroNet
Tags (2)
  • 4764
  • GaryMontague22
