Recovering information from a functioning ACX781
  • Recovering information from a functioning ACX781
  • RandyDavis
    RandyDavis
  • Alan_Wood
    Alan_Wood
  • BillNeville
    BillNeville
‎2018-09-06 01:05 PM
Last Updated: Guinan RandyDavis Guinan ‎2024-12-17 09:05 AM
Customer database server crashed with no backup. Customer needs to re-create the access control database. What data can be recovered from the acx781's?
Andover Continuum
  • Netcontroller
  • ACX781
  • Hyperterminal
  • Terminal mode
Customer database server crashed with no backup. Customer needs to re-create the access control database. What data can be recovered from the acx781's.?
Using terminal mode into the NetController the customer can dump out from the controllers all the doors, numerics, inputs, outputs and PE code. The personnel records are not retrievable, however, as they are not stored in text format in the controller.
Tags (2)
  • 6570
  • AlanWood24
