Problem communicating across the LAN on Windows 7 and above PCs
  • Problem communicating across the LAN on Windows 7 and above PCs
  • Cody_Failinger
    Cody_Failinger
  • Chris_Asbury
    Chris_Asbury
  • CraigEl
    CraigEl
‎2018-09-07 07:02 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 11:13 PM
Continuum / Vista / I/NET / StruxureWare etc will not connect to any of the controllers on the LAN when using a Windows 7 and above PC.
Andover Continuum, EcoStruxure Building Operation, TAC INET, TAC Vista
  • I/NET 2.4x
  • Continuum
  • Vista
  • StruxureWare
  • Windows 7 8 8.1 10
This is due to Microsoft improving their security in Windows 7 and above that will now block many types of connections across a network.
To enable communications across the network;
  1. Disable all firewalls and any Anti-Virus software on the PC. (SE laptops, right click on McAfee shield, Quick settings and un-tick everything, this will temporarily disable the AV and firewall)
  2. Disable User Administrator Control (UAC) (As per Disabling administrator rights messages in Windows 7 OS and above)
  3. Re-install I/NET Seven / Continuum / Vista etc
Labels (4)
  • TAC INET
  • 4742
