Options for archiving extended log data
Select a Country
  • Options for archiving extended log data
  • Cody_Failinger
    Cody_Failinger
  • sesa116095_brid
    sesa116095_brid
  • CraigEl
    CraigEl
  • sesa119747
    sesa119747
  • Alan_Wood
    Alan_Wood
‎2018-09-11 06:03 AM
Last Updated: CraigEl Champion ‎2022-08-09 07:27 PM
Options are needed for truncating large amounts of extended log data, but with the ability to report on that data
Andover Continuum
  • Continuum
  • Windows XP
  • Windows 7
  • Windows Server 2003
  • Windows Server 2008
Extended logs data can cause the Continuumdb to get large and needs to be truncated with the ability to continue to report from the old data
  1. Set up automatic truncation of extended logs (See the Check Purge Interval section in Stand Alone Continuum using SQL Server 2005 Express is not purging the ExtendedLog table) Ex. Year, 180 days
    Make a copy of the Continuum database on the existing server. In this scenario you would have ContinuumDB and ArchiveDB. Use one of the Cybers via Workstation Initialization) to temporarily switch to the ArchiveDB for reporting purposes and then switch back.
  2. Purchase the Extended Log Archiver uses a separate db for the archived data and truncates data from the Continuumdb automatically. For more information email COE@Buildings.Schneider-Electric.com
Tags (3)
  • 14453
  • add-on
  • software
