Object type Specified is invalid when exporting points
  • Object type Specified is invalid when exporting points
  • Cody_Failinger
    Cody_Failinger
  • CraigEl
    CraigEl
  • JohnBoehmer
    JohnBoehmer
‎2018-09-11 05:37 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 01:47 AM
When using Send to Text to export controller points to a text dump, some points are followed by the following error.
VidioId - The object type specified is invalid.
Andover Continuum
  • Video
  • Export
  • Send to Text
These errors are usually caused by is a “null” value primed in the DB for those attributes
These errors are benign and should be disregarded.
See also Errors when exporting extended log points.
  • 12179
