When hovering the mouse cursor over the bang (!) icon in Continuum Explorer, the tooltip does not display any information indicating the issue.
Andover Continuum
- ACX57xx
- Windows 7
Windows 7 may suppress tooltip display for certain UI elements, including the bang indicators in Continuum Explorer.
To enable tooltips when hovering over the bang icon, modify the Windows Registry as follows:
⚠️ Important: Always back up the registry before making any changes.
- Open the Registry Editor (regedit).
- Navigate to the following path:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced -
Locate or create the following DWORD value:
Value Name: ShowInfoTip
Data Type: REG_DWORD
Value Data:
0 – Tooltips Disabled
1 – Tooltips Enabled
Set the value to 1 to enable tooltips.
Exit the Registry Editor.
Reboot the system to apply the changes.
Additional Notes
- This registry setting controls tooltip visibility system-wide, not just in Continuum Explorer.
- If tooltips still do not appear after rebooting, verify that no group policies or third-party software are overriding this setting.
