NPR Connectivity over the Internet
  • NPR Connectivity over the Internet
  • Roger_Bently
    Roger_Bently
  • CraigEl
    CraigEl
‎2018-09-06 08:28 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 09:47 PM
TAC INET
  • I/NET
  • NetPlus Router (NPR) Series 2000
In most cases when communication occurs over the Internet, firewalls are in place to block non typical ports.  I/NET utilizes Ports 50069 (set by default).  These ports usually need to be configured within routers to allow I/NET to communicate correctly.
Receiving messages from one I/NET System to another over the Internet through an NPR that is behind a Firewall. In order to accomplish this there are several steps that need to be done.
  1. Configure the NPR with a static IP Address.
  2. Set the Host Masking to send and receive messages (this will not be available when directly connected).
  3. Remove the NPR from behind the firewall and connect outside the firewall. Connected directly to the Internet.
  4. Set the Host Masking so that it can receive messages.
  5. Once communications have been established, You can now replace the NPR back behind the firewall.
Also refer to Which ports must be open on a commercial router in order to communicate with an NPR over a WAN? which discusses ports utilized by I/NET.
For cases where you are using the Xenta Server 527 NetPlus Router (NPR) refer to TCP/IP Ports used by the I/NET system: UDP Port Settings.
  • TAC INET
  • 1017
