TCP/IP Ports used by the I/NET system: UDP Port Settings
  • TCP/IP Ports used by the I/NET system: UDP Port Settings
  • Derrick_Ratliff
    Derrick_Ratliff
  • CraigEl
    CraigEl
‎2018-09-07 04:17 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 12:21 AM
  • Ports are required to be open for I/NET to communicate
  • Need to know the UDP TCP/IP port settings for I/NET.
  • File Equalization failure or NPR devices not coming online
  • Some links (NPRs) are showing offline and can not be connected too, while others work fine.
TAC INET
  • I/NET
  • NPR
  • NPR-527
A Firewall may be blocking ports required for File Equalization and I/NET communication to occur.
You will need to work with the IT department to verify these settings.
  • I/NET communications occurs through port 50069.
  • When using File Equalization you will also need to ensure that ports 1433 and 1434 are open as these are used by SQL.
  • Integral DVR communicates to I/NET on port 18772
For systems with 527 devices or other Xenta servers, please review Ports used by TAC Vista System.
  • TAC INET
Tags (4)
  • 4368
  • inet
  • openings
  • tcpip
