Modbus points polling mechanism
  • Modbus points polling mechanism
  • RandyDavis
    RandyDavis
  • GavinHe
    GavinHe
  • PeterLarsen
    PeterLarsen
  • sesa139513
    sesa139513
  • sesa119747
    sesa119747
  • HenrikTarpgaard
    HenrikTarpgaard
  • Dave_Shore
    Dave_Shore
‎2020-11-03 10:44 AM
Last Updated: Sisko GavinHe Sisko ‎2023-03-31 02:51 AM
How and when are Modbus points polled?
  • Building Operations Enterprise Server
  • Building Operation Automation Server
Need to understand the Modbus poll mechanism
Consult the 'Modbus Deep Technical Reference' chapter of EcoStruxure Technical Reference Guide
Or use WebHelp to find information on the Modbus Poll Manager, which manages all polling of the points/data and devices, and the Poll List which contains all the current subscriptions (eg. data being referenced within Programs, Listviews, Graphics, Logging, etc)
These mechanisms isolate the Modbus Polling from programs and graphics.
Note:
  1. For each network, the poll manager operates with a poll list and a poll task.
  2. If a Modbus Object value is only required for logging purposes, then the  "Requested poll interval" is set to a high number (typically 2,147,483,647 ms) This means the object values are not currently being polled.
    When the time arrives for the log value to be collected, the "Requested poll interval" is set to 1000ms, until the value is collected, at which point it reverts to this higher number.
Tags (4)
  • 13577
  • GavinHeward23
  • PeterLarsen20
  • PeterLarsen24
