Menta modifications are not saved into the Vista Database
  • Menta modifications are not saved into the Vista Database
  • CraigEl
    CraigEl
  • PeterLarsen
    PeterLarsen
‎2018-09-10 10:31 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 04:44 PM
When you make a change to the Menta file and save that file back into Vista the changes are not available in Vista.
An alarm appears stating ("Object does already exist " when expanding file in database)
TAC Vista
Vista 5.1.7
In some earlier versions of Vista, illegal characters were allowed to be entered in the Menta program specification name.
Illegal characters in the program specification of a Menta file describes more on that problem.
Rename the Menta program specification name. No more than 12 character and no spaces or illegal characters. Refer to Menta Warning: Syntax error for illegal characters which can not be used.
Then generate the OP tree for the Menta application and save into the Vista database.
  • 11018
