Menta Warning: Syntax error
  • Menta Warning: Syntax error
‎2018-09-06 12:55 PM
Naming a point in Menta results in a pop up error
Warning
Syntax error
TAC Vista
Menta
Special characters are not permitted in the names of Menta signals.
Remove all of the following characters from the Menta signal name:
  • space
  • . period, ? question mark
  • - dash (hyphen)
  • \ backslash denotes the Menta module name separated from the Menta signal name. One is permitted, the second will cause a syntax error
The best rule to go by is to use nothing but alphanumeric characters and (_) underscores in Menta naming conventions.
  • 6996
