It is not possible to get a Xenta Server or 911 online in TAC Vista.
  • It is not possible to get a Xenta Server or 911 online in TAC Vista.
  • RobertAndriolo
    RobertAndriolo
  • PeterLarsen
    PeterLarsen
  • Jonas_Brissman
    Jonas_Brissman
  • sesa150555
    sesa150555
‎2018-09-06 03:53 PM
Last Updated: Picard RobertAndriolo Picard ‎2022-12-01 06:12 PM
Not possible to get a Xenta Server / 911 online in TAC Vista.
It is possible to ping it and connect to it via a Web browser using ports 443, 80, and Port 1068 is open, but it is not possible to get online in Vista.
TAC Vista Server
  • TAC Xenta 911
  • TAC Xenta Server
The problem, in this case, was that another Vista server was connected to the Xenta Server / 911.
This could have been from a technician or the customer who started Vista with this database loaded and had the device online in their Database.
The Xenta Server / 911 will only communicate with one Vista Server at a time and will close the connection if another Vista tries to communicate with it.
Using Wireshark it is possible to monitor this scenario as shown below:
  • Packet number 57439: Vista is trying to establish communication with the Xenta Server or 911( sending an SYN).
  • Packet number 57440: The Xenta sends an acknowledgment on the SYN from Vista, but with the window size set to zero, this is because the Xenta can't buffer information as a computer does.
  • Packet number 57441: Vista  sends an acknowledgment on the message from the Xenta
  • Packet number 57448: The Xenta sets the correct window size.
  • Packet number 57449: Vista starts to communicate
  • Packet number 57452: The Xenta closes the communication to the Vista server
Ensure only one Vista server is started when the Xenta server / 911 is included in the database.
Tags (8)
  • 7763
  • offline
  • PeterLarsen22
  • shark
  • wire
  • wireshark
  • xenta731
  • xentaserver
