I/A Series Software Compatibility with the Windows 7 Professional Operating System
  • I/A Series Software Compatibility with the Windows 7 Professional Operating System
‎2018-09-07 11:49 PM
Last Updated: Crewman ContentModerator ‎2025-10-15 03:38 AM
TAC IA Series
  • Microsoft Windows 7 Professional operating system (32-bit, 32-bit XP Mode, 64-bit XP Mode)
  • WorkPlace Tech Tool (WPT) 5.7 and later
  • PSI / XPSI  4.1
  • MNCI 4.0
  • MICROFLO Balance 4.0
  • PSOPRIF 11.6
  • Tree Tech 3.1
  • LON Flow Balance 3.0
I/A Series software should only be run on tested and compatible equipment to avoid problems with software or hardware.
See Product Announcement PA-00163 for detailed information on compatibility of current
I/A Series Software tools and Windows 7. (Updated 3-14-12, replaces PA-00114 with PA-00163).
See I/A Series (Niagara) R2 Windows Compatibility Matrix for information on the I/A Series (Niagara) R2 compatibility
See WorkPlace Tech 5.8.x and 5.9.x Operating System and Microsoft Visio Compatibility for information on the I/A Series Workplace Tech compatibility
  • TAC IA Series
  • 5128
